I have been having a problem with one of my Cooper Z-wave Dimmer Switches. It is in a 5 Gang (Not that would make any diffrence).
What is happing, When I push the switch to turn off the lights the Dimmer Switch shows that the lights are off but the Lights stay on. I have to pull the Little Pin on the Right side to kill power to the switch to turn off the lights. It seems that it works fine untill it warms up. In other words if I turn on the lights and back off in just a few min it will go off after the switch has been on for some time then it wont go off. Also when an Z-wave command is sent it thinks the lights are off even thoe they are still on.
I have replaced the switch and still having the same problem. Could there be a wireing problem that might be causing this. I replaced all 5 and still haveing the same problem with the same switch location (Allways the same set of lights.)
Thanks in advanced for any help with this
