Sacedog
In a lot of threads recently, I have noticed that many of you are using the Aprilaire Distribution Panel to hook up more than one 8870 to the protocol adapter. While the Distribution Panel is necessary for those situations where you cannot get power to your thermostat from your HVAC equipment, it is not necessary for those who have power at the thermostat already.
In the past, I have just used a B connector to crimp together the flying leads from the protocol adapter, to the Cat5 from the thermostat. Recently, I needed to troubleshoot a stat, and it was a pain to cut the flying leads, restrip, and reconnect multiple times. So I finally decided to connect the Cat5 cables to the flying leads using a standard block. This way, I can disconnect thermostats, without having to cut the flying leads. While this isn't as easy to troubleshoot as using the distribution panel, my thought was; once everything is connected and working, it would be pretty rare to have wiring problems. So I decided that this would be a great way to save $85, and to get one less thing out of the can.
