urbanscribe
Pulling my hair out a bit
Trying to wire up the ELK-M1XRFTW Two-Way Wireless Transceiver when using a ELK M1DBHR M1 Data Bus Hub For Retrofit
I've tried to connect M1XRFTW Transceiver a couple of different ways on the M1D Bus BHR but keep having usual termination or connection problems (connection lost, can't find the transceiver). There is an existing ELK-M1KPB Keypad on Branch 1 terminated. The main board is terminated as per usual. The M1XRFTW is also terminated.
Any insight on how to wire up the M1XRFTW transceiver with the M1DBHR bus and termination setup?
