apostolakisl
Just be careful that there isn't any way that the glycol can contaminate the beer. It is quite deadly. It happened about 20 or 30 years ago to a winery in Italy and a bunch of people died.
jamesg said: I have been working on perl code to control the board and I am using it explicitly for my uses. My big motivation for doing it was template/variables in the PLC code without having to do multiple steps. If people are interested I will release this code publicly when it is more complete.
How close is your perl code to being complete? I'd love to use it. The code commenting and naming of variables are valuable capabilities.
3. I’d like a small widget (Visual Basic?) Program that showed the inputs and outputs states for a number of webcontrol boards and buttons to change the outputs, for unto 8 webcontrol boards, currently I have 5 running on my network) Has anyone written one of these?
Suggestions for new firmware...
1. a variable that is TRUE when the clock is closely synchronized to NTP, and FALSE when clock can not be synchronized to NTP.
2. I’d like a command that wrote HTTP urls so i can have webcontrol1 could set outputs etc on webcontrol2. either by firmware inside or by small widget (Visual Basic?) Program – either way would be fine, Has anyone written one of these?
4. An easy way to update firmware over the LAN - maybe “clone firmware from other board” at 192.168.n.n
I believe the upgrade is not a matter of policy, but of technology. The product does not have field-programmable devices. Only factory equipment. For a product that changes as often as WebControl the lack of field upgrade is a real downer.
The problem with this philosophy is that anyone who tries to use WebControl in their system needs to develop integration software for a specific version of the WebControl. The engineering that was done to integrate a specific version of WebControl cannot be used for the next customer because when that next customer orders the WebControl they get the "improved" version. Most of the integration software that I have deveoped was done using techniques of learn as you go with the WebControl. There was no documented API that I could depend upon.Based on customers' feedback and requests, we add functions and features in all the time, but many users may not really need all those newer features.
You really need to find a way to let people upgrade the firmware at home. If that means a small piece of hardware or something that plugs into the board to protect some encryption or something then I think you should do it. But mailing in a $35 item and waiting 10 days and having it cost you $20 to get it updated, is really pretty backward.Hi Michael, Sorry for the frustration.
The migration from BRE to PLC is significant. However, other incremental updates on BRE and PLC firmware are not that significant different. Added features and funcitons do not alter existing funcitons. We are focused on the PLC firmware development in last year, no plan to change that in the future. In the /getall.cgi reply, we actually report the firmware version number to help ease the pain of software integration.
Adding functions and features does cause trouble for software integrators. If you have any suggestion howcan we do better, please do let us know. We do love to hear from you. A lot of HomeSeer users are love to use your program to support WebControl in their setup.
