beelzerob
Yes, I set all the ports for Low Latency.
The Ocelot has had no issues that I can tell. I'll hook up a couple more devices tonight that were giving me issues (datanab and RCS TR-15) and see how they do.
I checked it this morning, and sure enough, the OnQ had disconnected several times.
So far as I can tell, the reason for the disconnects is because it is occasionally not getting a reply to "are you there?"....basically just a heartbeat sensor. It doesn't happen every time I check for a pulse...just sometimes. So, that sounds like a message that isn't getting passed along...which again, could be anything down the line...router, switch, quatech, or ALC.
Tonight what I'll do is move the ALC to the one native port on this PC and see if it still has that issue. If so, then that leaves it being the ALC (or possibly the CQC driver, but I highly doubt that...the driver is of unquestionable quality).
I'm fairly certain I can code around this....just simply make it more tolerant to not getting back a pulse (maybe administer a little ALCPR too), but I'd rather not. In my opinion (and greatest desire), it should just work.
