I am about to order an Elk M1 Gold with the ISY 99i package. A couple questions I had were
Should I go with closed/open contacts for doors and windows? is there any pros/cons?
What kind of wire should I get to wire up the contacts?
I am also thinking of using Motion Sensors... I have 2 small dogs (30lbs) and a cat, can someone recommend a good one?
I want to tie smoke/co detectors in, do I need specific detectors or can standard ones integrate?
I currently have about 9 Insteon switches, can anyone elaborate if they have something similar set up?
My house is a split level, I can access all the windows/doors via drilling through the bottom plate/top plate in either the attic or basement. Is there any best practices on this?
Also, I welcome any other comments/suggestions...
Thanks for the input.
