Haiku Radiora Keypad presses from haiku
caraj
Hi
I have been using this app for a while and it's been working great for my home.
Can anyone tell me how to press/program a radiora keypad press from the haiku app?
I can control all rooms from the "rooms" page and also all lights from the "lights" page.
I have pc access but can't figure out how to program keypad presses.
Thanks!
lupinglade said:
You could setup a button in PC Access and then use that button in Haiku perhaps?
Hi, And thanks for the response but I don't think I can program a button to control a keypad press
I won't be able to test this until Sunday.
lupinglade said:
Perhaps I misunderstood. Could you explain in more detail what you are trying to do?
wow I wish I could figure out how to get notifications when there is a post in a topic I posted...
Basically what I want to do is have hai press my keypad buttons that I programmed into the lutron radiora2 processor.
so if arm away and then HAI should send a command to the lutron keypad button "away lights" programmed into my radiora keypad. this keypad is programmed as integration id 68 and button 3 on the 6 button keypad
I'm not that familiar with RadioRA. Is it possible to trigger these things from the HAI controller normally?
If Lutron has an HTTP API available for these things you should be able to integrate it via scripting. Serial may work too if you were to hook it up to the machine running HaikuHelper.
