Hi,
I am looking for ideas/suggestions as to rain sensors. The main reason i want is to not water while it is raining. I have 7 zones all controlled by ElkM1 Relay board. I have automation rules controlling the watering times and zones. THis has worked really well, and I have actually programmed in a sprinkler bypass rule, so i can turn off watering, while the bypass is active. I want to automate this bypass so that when a rain is detected in the rain sensor it automatically goes into bypass mode. Also when the rainsensor "drys up", that is clears the bypass mode.
Any suggestions on a rain sensor that could be hooked into my ELK System?
Thanks in advance for your suggestions
Jeff
Jeff
