Where does the RC2000 get outside temperature information from?
I have two RC2000 units, one is hooked up to a duel fuel system and the other is hooked up to a heat pump with aux electric. The duel fuel unit is wired to an outdoor temp sensor the second unit is not wired to a temperature sensor - but still displays an outdoor temperature. However, it doesn't seem to display the same temperature as the first unit - instead it seems to pick one of my other temperature sensors hooked up to my HAI to use? Is that accurate?
On a side note - I simply hooked up the RC2000 to the temp sensor that was connected to my old Honeywell thermostat - is that supported or do I need to replace that temp sensor with HAI sensor? The temperature seems to be accurate -- however, I have noticed that when it displays the outdoor temp on the thermostat it is constantly changing between two values while it is being displayed.
