davetoolin
Trying to install and RCS TR16 with my Elk M1 system.
1) got the TR 16 working stand alone - not connected to my heat pump not connected to the M1 - everything seemed to be working fine. all the right leds in the control module on at the right times.
2) Connect it to the M1 thru the serial expander. got it communicating sends it net set points etc....
3) Connected up the heat pump and then the trouble started.
It won't go into cool mode. the fan comes on, heat mode works fine. but not cooling.
4) took it all the way back to stand alone and it still doesn't ever go into cool mode.
Read thru alot of post on this site. Seems like the TR16 can sometimes have a mind of its own. Is it possible that the M1 sent it some disable command??
Is there a way to reset the RCS TR16??
Anyone have any ideas??
Dave
Dave
