I am getting a bit frustrated with my Insteon thermostats.  I have 3 of them and I have them mostly locally programmed for day/nite changes but I like to use my iPhone with eKeypad to remotely control them some times.  Pretty much since day one, after some number of days has passed, the thermostats stop responding to any Insteon commands, either by my iPhone or the ISY99i that controls the Ineteon network.  I have the go around and physically unplug the Insteon modules from the thermostats and then plug them back in to get them working again.
Unfortunatly, it seems that every time I really need the control, it's just not there.
I have seen other reports that indicate that this happens quite a bit with these thermostats.
My Insteon lighting is fairly stable and works well with the ISY99i. The thermostats continue to work fine as basic programmable thermostats when this happens.
Is this how it goes with these? If so, what direction should I take to replace these?
Currently I have an Elk M1 with M1XEP for alarm use, ISY99i for Insteon, about a dozen Insteon switches and eKeypad Pro tying it together for me on my phone.
I also have a relative recent version of Homeseer Pro that I have not gotten around to playing with.
Based on what I have and want, any ideas what direction for thermostat control I should head in?
Price is a concern and I really don't want to spend $1000 for 3 thermostats if I don't have to.
I can easily get under my house and wire for serial to new thermostats but the serial ones are really expensive, although I could wire them directly to the Elk using the Elk module but how to control for iPhone?
How about zwave using Homeseer Pro as control?
Other options?
Thanks for all your help!!!!!!!
Other options?
