apostolakisl
Putting home automation devices directly on the IP network seems like a security mistake. Every device is exposed if someone outside the house wants to monitor you or control your devices. E.g. turn on your light and see if anyone is there to respond. At the early stages it has security through obscurity but I wouldn't want it to catch on.
If you have a separate network (e.g. Insteon, UPB, Z-wave) with an internet-enabled controller, you only have to worry about security at that one point. And if there is a problem, you only need to update/upgrade that one single device, not every single light switch.
This becomes even more of an issue if you use it for functions other than lighting, of course.
I suspect that that a wifi ip environment would have its security globally controlled by some sort of network coordinating device rather than individually controlled at each item. But, the earlier point about power consumption and cost of each device may superseed, but I could be very wrong. Take for example my eyefi card for my camera. It manages to upload big chunks of data via ip without undue stress on the camera battery. The micro amount of data needed for a light switch controller seems like it should take practically zipo on power consumption. But unlike my wifi card, a light switch (or other HA device) would need to be "listening" constantly. I guess the trick would be to have a standby state that takes a fraction of watt to maintain.
