Replacement for HAI's 4 Ch DVR/Encoder
mariomp
I have a client with existing 5.7e Touchscreens, 4 analog cameras and a dead 68A00-1 HAI Network Digital Video Recorder.
http://www.smarthomeusa.com/ShopByManufacturer/HAI/Item/68A00-1/
Those that know that product, know that the DVR takes analog cameras in encodes them into IP stream.
What have you been installing to get this functionality?
Should I just force him to update the 5.7e touchscreen and use the new android based touchscreen?
What options do we have then? I haven't played with any IP camera stuff...yet.
CJW-PIC said:
EverFocus will do the job. Will convert Analog to MOTION J PEG
And a 4 channel model will generate 4 separate streams or just one - main one?
Do you have any specific model numbers?
I would suggest and Axis 4 channel analog to IP converter. Works perfectly with OT 5.7e/ OT Pro and OT 7 , each stream has it's own independent IP address and simple MJPEG cgi? request stream along with sizing. They are a bit expensive but work great. For recording, use Samsung stand alone DVR. I use geovision along with a PC and an interface back to the Pro II to toggle devices and respond to inputs.
