Wondering here if I should open a ticket relating to this issue.
I have a mixture of Omnitouch 5.7's and Omnitouch 5.7e's.
I also have in place the combination video hub / Omnitouch 5.7 power hub.
While I have the CCTV cams displaying in the Omnitouch 5.7's and Omnitouch 5.7e's I have never used the pop up video feature on the Omnitouch 5.7's. I went to my HAI software and software touchscreens for this stuff (just faster for me).
A day or so ago tested a CCTV single camera pop up with the doorbell ring. It doesn't work on the Omnitouch 5.7 screens.
I am reposting this message here.
Another personal concern is that the Omnitouch 5.7e's do a fine job displaying the configured cameras in PCA while in the Omnitouch Pro software (which resembles the Omnitouch 5.7e's) video configuration in the software configuration is only set up for the legacy Omnitouch analog to server configuration (Axis server) and doesn't behave like the Omnitouch 5.7e's. The only way to get around this is to use the designer to redo the Omnitouch Pro software screens.
II just updates to,3.14a on an omni pro 2, it has the analog video board/power hub and the original 5.7 touchscreens, I had a rule prior to,updating was 3.11, when door not ready display camera x on touchscreen x, rule has not changes but cameras no longer show on screens, any ideas?
Thanks and happy holidays
t doesn't work here either.
Here have firmware 3.14a on my OPII.
I have Omnitouch 5.7 / 5.7e screens up with the HAI analog video board / power hub feed by older analog cams and newer IP cams (using a decoder/encoder board) and the 5.7e screens configured to the IP cameras configured in the Omnitouch 5.7e screens.
Just paying attention here as the frontdoor doorbell never rings and I do much stuff in software.
I created an automation block to show the front door camera on the Omnitouch 5.7 screens. The PCA initial drop down for the cameras showed the Omnitouch 5.7e configured cameras (IP). None the less the Omnitouch 5.7 screen did not show the camera popup when the doorbell event occurred. I went back to PCA redoing the automation lines and this next time it just showed the camera numbers as seen on the Omnitouch 5.7 screens. Saved the configuration to the panel and tried again. It did not work. I did add a post to log thing at the end of the doorbell event and posted the event fine to the log.
