streetlightpeople
You are correct. The fiber modem is also a router than then connects to my WiFi (which is also a router) that then connects to my switch. As you mention, it's all working now, so, I'll probably leave that alone.Yeah, so they gave you a router with the service. You may want to get rid of it and just use your own but if it's all working then go with it.
No need for both routers though so you can disconnect the old one also.
By data cable he meant an ethernet cable going straight to the ethernet port on the omni. No need for a crossover anymore, everything is auto-mdi now so even if the omni isn't, the laptop/pc would negotiate.
Regarding connecting a pc directly to the ethernet port on the OmniPro II, what would that accomplish? (I believe) I understand the serial connection is an alternative if let's say ethernet isn't working, but what would the direct ethernet connection accomplish?
