streetlightpeople
I didn't look for it and I'm not sure where to find it. Can you advise?
			Hey;Does the integration of video cameras work with OTP?
yes
Do you know of any place/anyone who would be interested in selling their license of OTP - 1131.
You do not need a purchased license now for OTP per Leviton CS
pete_c hoping your still available for HAI consulting. Recently our internet service was changed from coax to fiber. New modem, new ip address, same mesh wifi and router. All communication with the HAI Omni Pro II controller stopped. Of course I updated he ip address on the iphone app (as I have been doing for many years when required) but app says "Error: Unable to Connect". I also tried connecting using Dealer PC Access with the ip address of 192.168.1.100 as I have many times in the past however I cannot get a connection. Obviously this is a very big problem. Without communication nothing will work, not even the Omnitouch 5.7e touch screens. Any thoughts on what I should look for or try??Great news!!! You can also see the configuration using a serial connection to the panel without the keys and IP...
New modem?pete_c hoping your still available for HAI consulting. Recently our internet service was changed from coax to fiber. New modem, new ip address, same mesh wifi and router. All communication with the HAI Omni Pro II controller stopped. Of course I updated he ip address on the iphone app (as I have been doing for many years when required) but app says "Error: Unable to Connect". I also tried connecting using Dealer PC Access with the ip address of 192.168.1.100 as I have many times in the past however I cannot get a connection. Obviously this is a very big problem. Without communication nothing will work, not even the Omnitouch 5.7e touch screens. Any thoughts on what I should look for or try??
I thought about this but figured out issue before attempting (see my post 2/19/2025). But if I were to attempt a serial connection to the OmniPro panel directly, would this be done using Dealer PC Access and setting the IP address in Dealer PC Access to what the OmniPro panel IP address is? And is the crossover cable required (will it work with regular serial cable?) or just "best practice"?Try hooking a data cable directly from pc to OmniPro. will need to set ip address on pc. best to use a crossover cable.
what is the state of the two leds by the ethernet connector on the OmniPro?
Yeah, so they gave you a router with the service. You may want to get rid of it and just use your own but if it's all working then go with it.@pete_c @Frunple
Thank you both for your inputs. The system works again. Here's what happened-
The new "fiber modem" is creating the Default Gateway IP address (I believe it's the DHCP) that my existing router and all other devices on my network are then assigned there IP addresses from. The Default Gateway became 10.11.1..1 therefore the HAI panel (not being DHCP but having a static IP address of 192.168.1.100 did not see the network. I manually assigned the HAI panel IP address to 10.11.1.100 as well as pointing the Omnitouch 5.7e touch screens too and everything came to life. Boy was I happy about this one.
One a similar but different note, has there been any update in the ability to get Automation Studio to customize the Omnitouch 5.7e screen?
Again, can't thank you guys enough for sharing your time and knowledge with me.
I do not have the install manual, and I do not have a HAI serial cable. (I am a fairly capable homeowner, not the installer). Do you know of a link to the install manual or haver a pdf you can share and any idea where I can get an HAI serial cable? (potentially for my future use)leds - one should be solid on (the link led). the other should flash when moving data.
serial connection to OmniPro ignores any ip info. You need a serial port on pc or usb to serial adapter as well as HAI serial cable.
Do you have the install manual? It is described in there.
