Hi,
I have a 30yr old Napco Magnum 1010 system that is still working fine. But the digital keypads are starting the wear and are do not respond to all the buttons. I can get around it a bit for the alarm codes (ex: don't use #6),but it is a nuisance when it comes to zone bypass.
Is there anywhere I can pick up compatible replacement keypads? Can I clean the circuit boards effextively if I disassemble a keypad with Isopropyl alcohol? Do other Napco keypads (ex from the Gemeni line) compatible with the Magnum series? Or something more recent? Where would I be able to buy replacement units?
Eric
Eric
