OK this makes me even more comfortable with 22 volt clamping. I bought two new Ditek 4lvlpx for ten dollars each on Ebay and was having second thoughts about using them but now I think that I did well. I hope that we don't have any thunder snow storms, I probably won't install these until we get a warm day in the springtime.RAL said:If the clamping voltage is too close to the operating voltage, the MOV may conduct under normal operation, which would do two things. On a data bus, it would short the data signal to ground, corrupting the data and causing errors. Each time the MOV conducts, it will use up some of its protection ability and service life, and eventually will fail. And if you do get a real surge before the MOV totally fails, the MOV may no longer be able to dissipate as much as it is supposed to.
One more question, what is the significance of the 18 volt max continuous operating voltage on this device?
Mike.
