Neurorad
If you ever buy 'fish sticks' - fiberglass rods, as linked above, make sure you get the really thin ones, that glow in the dark. I bought thicker ones, and I will replace them soon. Too stiff, and I've already trashed 1 of them. Much better than fish tape, if you only buy 1 or the other.
I would remove one of the bottom knock-outs from the box (don't know if that's against code), attach a string to the existing cat5, and pull out the existing cat5 from below, pulling the string down. Then pull 2 new cables together, with the string.
That magnet/noodle trick sounds pretty awesome!
But I would use the existing cable, without sticks.
The existing cat5 is probably behind the bat insulation, all the way from the box to the hole.
If you screw up, and need to cut drywall, make sure it's to the side of the existing box. Then, add a scene switch to the existing bank of switches - make it a triple gang, using a retro-ring
Or just repair the drywall.
Edit - I don't know if the ALC scene switch is OK to go in a LV box.
