felixrosbergen
Hi Gents,
I need some advice on quantities and sizing of conduits.
My strategy for my new construction home is to not have the building put in excessive wiring, but to have him add a LV bracket to all wall switch location and run a flexble conduit down to basement (in case of first floor) or up to attic (in case of 2nd floor). At the CATV, Cat5e location it will be the same, run a flex conduit up or down. Is this a common strategy? It seems simply, but i'm not sure how much all the conduit and brackers are going to cost me. I imagine it will be cheaper than paying an electrical to run all the cabling i want (especially since i may not use half it initially or ever). Any comments to this strategy greatly appreciated.
I don't envision doing any distributed component video or similar, it's mostly basic coax and cat5. What size flex conduit do i need to run 2 coax and 2 cat5 through one of these flexible conduits later? And what it is max size that a 2x4 framed interior wal can accept.
Then for the main runs from basement to attic is am asking for PVC conduit (probably through an interior wall). Any suggestions on reasonable quantity and sizing?
For reference this is a 2500 sqf 4 bedroom house in which is expect to do some moderate HA, for example:
- Elk alarm/automation with hardwire PIR's, etc
- Russound whole home audio
- OnQ lighting
So by rough estimate i expect to need to run the following from the basement to the ceiling at a later time through the PVC conduits
- 4x RG6QS for satelite
- 2x RG6QS or similar for XM/FM antennas
- 4x 14/4 speaker wires and cat5 for whole house audio
- approx 10 RG6QS for CATV/Sateline distribution
- approx 8 Cat5e for LAN (but could ofcourse put a switch in attic, but attic is not heated so i prefer not to do this)
I assume that for a 2x4 frame internior wall you can probably go no larger than a 2' conduit, my guess is that i will need about 4 of them. I sincerely hope they can be straight shots up from the basement.
The attic will be insulation mats, not blown in (yeah!!).
Comments greatly appreciated. I need to have all this stuff defined by monday morning.
- OnQ lighting
