Automate said:
Yes, but keep in mind you are not trying to cool the house. The whole house is already pre-cooled. You are only trying to extend the time without running AC. Not eliminate it.
ECM circulation fans use very low amounts of power. You don't need a lot of air flow since your not trying to keep the AC coil from freezing over.
If I run my attic vent fan on high speed for 12 hours at 10 cents per kWH it cost me 23 cents and its a PSC motor.
A typical hvac fan in a 3 or 4 ton system is going to use around 500 watts. At his daytime electric rate, that is going to add up fast. And if you have 2 of them count it as 1000 watts. Not only the 1000 watts in electric cost, but all of that turns into heat. Now you need 100% efficient transfer of heat from the air into those sticks. .. which isn't even going to come close to happening, they are sticks, they have no heat exchange fins or anything. I doubt the air coming out the vents would even be 1 degree colder than when it went in. You would really be better off running a ceiling fan over your head for some wind chill.
Now consider that those sticks are all warmed up when you go to low rate time in the evening. You flip on the compressor. But instead of nice 40 degree air, you get warmer air since the sticks are dumping heat into the air. So now you were hoping to at least get the house cooled down by bedtime, but instead the thermal mass of these sticks is blocking rapid cooling of the house.
You could put the sticks on the return side, but in that case you would have to get your house down to 70 or so for quite a few hours to get those sticks to solidify again since the return air (if your system is designed with optimal return air intakes) is sucking up the hottest air in the house. They really don't "freeze" until the temp is a couple degrees below their set-point, if you look at the graphs on their website. If it took 10 hours to melt the sticks at 80, then it should take 10 hours to freeze them at 70.
I'm telling you, this isn't going to work very well at all.
And I don't know how you are getting your attic down to outside temp with just a single 100 watt exhaust fan. No one around here gets that kind of performance. The roof decks get up to 150 (or more) degrees which basically act like a radiator shining IR down onto the floor of the attic. Even if the air in the attic were somehow kept to 105, the IR would still be beaming down.
I think the money on this product is all between the living space and the solar irradiated surfaces of the house. . . the roof/attic, followed by south exposure then west then east.
