this falls cleanly into this thread only because i am trying to contain all of my elk setup topics into one thread...but it has nothing to do with programming ELKRP, which i am still interested in figuring out. the below is from a post i have on the
cqc forum, but it seems that this would also be an appropriate topic here on CT.
having installed my elk, finished wiring of all my russound zones and having the viking slp in hand, i am ready to undertake the final wiring. as a picture is often worth a thousand words, below is an illustration of the wiring i am trying to accomplish. but before i hook everything up and destroy some equipment, i thought i would ask for feedback on my plan. My concerns are in lower left of the illustration, but to lay them out again:
Does it matter the order that the twisted pair takes? Viking or M1 first?
Can multiple triggers be wired to the same 12v trigger input on the CAV?
Can multiple audio inputs be wired to single paging input on CAV?
one bit of functionality i forgot to mention is that i would like the doorbell to be a zone on the M1 which then can send a 12v trigger to the CAV so that a cqc .wav file can play. cqc would sense the need to play a .wav file via the cqc-elk driver.
i am pretty sure that i can get each of the desired bits of functionality to occur in my system on a standalone basis. my concern is getting them all hooked up at the same time into the CAV.
thoughts appreciated
to give a little more color on what i am looking to do, here is a follow up comment i made on the cqc forum.
gacevich said:
based on testing i have done, i have experienced the same "clipping" of audio on the cav. its only when there is a 12v trigger present that the audio plays cleanly. my plan is to use one of the 12v outputs on the ELK, triggered to the doorbell, and timed to the length of a wav file to be played from cqc. this should give me a personalized doorbell ring. additionally, i want to do caller id announcements when the phone rings and i am planning to similarly use an elk output trigger so the .wav file from cqc does not get clipped.
the way i look at it, its the viking that is the least used piece of equipment. it will be used almost exclusively for paging.
i'll let u know how it turns out after i get it all hooked up...assuming someone doesn't chime in (pun intended) with a reason not to hook up the multiple audio inputs and 12v triggers to the CAV.
