Finally getting to installing alarm in my garage.
Have a M1G to secure the main house.
The garage will be set up as a separate partition so it can be secured while we are home. Also, I would want notification/alarm if any of the garage doors were left open, or broken into.
I already have a M1DBH in the house box. There are 2 keypads and a m1XIN connected to it. I may add a few more keypads in future and will most likely need a P212S Power supply (all connected into M1DBH).
In the garage, I am looking to install an additional M1DBH to the garage (in order to only have one Cat5 running to house M1DBH. I will plug one (or two) keypad, one P212S Power supply, and one M1XIN 16 zone expander into the garage M1DBH.
In the garage, i will install motions, heat detectors, and magnetic contacts on all doors, all connected into the garage M1XIN.
Just to confirm, each M1DBH would need a RJ45 Termination plug, at the last slot, correct?
Alternatively, I may forgo the additional M1DBH in the Garage. Wanted to get feedback as to this setup.
