I'm new to this forum and to Premise. I have a Z-wave installation, so I thought I would give Premise and the Z-wave module a test drive. I read the entire Z-wave post a few posts down, and it looks like the Z-wave module has come a long way in the last several months! Good to see open, collaborative work!
I had trouble installing Premise on 64-bit Windows 7; however, I was able to install it in a 32-bit XP virtual instance running on 7. So far so good.
I imported the Z-wave module, and added it under Custom Devices. Now, I'm trying to figure out how to tell the Z-wave module on which com port to find the RZCOP. I can see ViziaRF under Custom Devices, and I can see two COM ports under Serial Devices. But, how do I tell ViziaRF which COM port to use? I'm sure I'm missing something simple.
While I'm at it, I have another related question about the Z-wave module. I have a Hawking HDRS1 Door/Window Sensor, which I have connected to an outdoor PIR. Does the driver support this Hawking device? It's the same device as the Everspring SM103. Since I don't have permission to post links yet, you can find the doc for this device by googling for the terms sm103 manual.
Mark
Mark
