snakevargas
I have a shed, about 40ft away that I'd like to run both a 120 VAC circuit and some shielded 22/4 for my elk sensors. The conduit run unfortunately has to be visible above ground, so I'd like to make it a attractive as possible. So, the questions:
1) Is it code-legal to run LV and HV together in a single conduit? I'm guessing probably not.
2) Assuming one did it anyway, would there be sufficient interference from the 120 VAC to prevent the sensors from working? We're talking standard door contacts.
3) How about Elk RS-485 for an expander?
I really don't want to have to run two conduits, but I suppose I will if I must.
Oh, and the title should have said "shielded", not "shielding".
