Signal meter
royalj7
Hey folks,
I was looking for the name and maybe a link to the signal strength meters the cable company uses to diagnosis your line. I have a problematic situation where I can't use amplified splitters on my digital cable line and it's driving me crazy (as well as costing me money trying a crap load of different splitters.) I have a feeling the meters are pretty expensive, but if I know the proper name for them I could see if one of the wiring companies locally would rent me one. They are the ones that report up/down signal strength in dB's.
Thanks!!
--Jamie
When I was setting up the cable at my sisters place, the tech just used the cable box itself. I guess there are diagnostics built in the firmware. Maybe if you can figure out the installer mode, you can use that. I did it after I got my inside lines in place and checked the signal that way. And its FREE!
electron
Administrator
Staff member
I had the same problem, but our local cable company (Time Warner) came out, did all the testing, and installed the right splitters/boosters, all for free. I will be relocating a lot of the equipment soon, so I will call them again and have them reterminate some of the wire and balance everything (they said I can call them anytime).
royalj7
Steve, thanks for the idea. I'll see if my box has one.
Electron, I've tried to talk with my cable company, but it's like talking to a Alzheimer's patient speaking Russian. They don't understand me half the time, and when they do, they promptly forget the next time I call. It's pretty frustrating dealing with them.
The problem I'm having is I have a DVR through the cable company and whenever I hook up a powered splitter I lose the ability to get VOD and channel guide. I though, humm, it must be an upstream thing. But I've tried 2 different bidirectional splitters and also my cable modem is not affected when the DVR loses its schedule (the modem uses an upstream channel also). I can use passive splitters, but much past a 1x2 the signal strength is so low the TV picture looks like crap. Ugh.
--Jamie
