cstrong3240
I'm stumped and looking for help. I've read other posts here about setting up the I/O 32 with Upstart for a garage door application. I'm running an Omnipro II. Receive Channel 1 works fine and I have a keyfob automation routine to arm, flash exterior lights and close the garage door as well as another one to disarm, flash lights at a different rate and open the garage door. I've also got a button programmed to open and close the garage door and that works fine in Snaplink and Haiku.
What I can't figure out is how to get the transmit part of the equation into the game. I installed a floor sensor and wired it into input 3 of the I/O 32. The I/O 32 flashes when the magnet on the garage door leaves or comes into contact with the reed switch on the floor, so it appears to be working. The open event is Garage Door Open and the closed event is Garage Door Closed, and both are set with a command of Activate in Upstart. Both have links. I'd like to be able to see the status of the door in Haiku and Snaplink and write a routine so that if the door has been up for greater than 5 minutes, it will close.
