ChrisWalker
I spent a bit of the day today re-researching INSTEON (due in large part to the very nice feature in the SmartHome catalog I received).
We haven't pulled a few hundred INSTEON devices into the lab yet to see how they do in a large installation, but we did do some initial math. I really like how simple the setup is, but the main problem (aside from the potential to introduce X10 instabilities into the system) is its non-mesh "wireless mesh" networking.
Here's the problem. Traditional "mesh networks" differ from repeater networks in one big way. They only intelilgently repeat commands. This is akin to needing to tell a secret to a friend across the room, and so you whisper it to the person next to you, who whispers it to a person closer to the friend, who whispers it to a person even closer to the friend, etc. until eventually your friend gets your message. This example is in an ideal world, where no changes to the message are introduced.
But insteon, while advertised as a "mesh network" seems to have a time-to-live repeating mechanism instead. In other words, a device sends out a message and says "repeat up to 4 times." Then, _every_ device that hears the message starts talking and ends with "repeat up to 3 times." And then _every_ device that heard the other devices talking repeats the message and ends with "repeat up to 2 times," etc.--until devices hear the message ending with "do not repeat" and the repeating stops.
So, this is effectively like using a brute force method to let your friend across the room know your secret. You can imagine in your mind the cacophony of people repeating the message, getting louder and more confusing each time. And in RF terms, having a half dozen or quite possibly a few dozen devices all try to repeat the same message at the same time is pretty much guaranteed to result in exceeding available RF bandwidth and data loss.
Anyway, back to my original question. I have no doubt that the engineers at SmartHome MFG, in creating INSTEON, saw the problems that would occur in a repeating architecture like this. They may have found a way around them.
So I'm curious--for those of you with INSTEON devices, how many do you have in a single home? How reliable have you found it to be, and how long does it take to turn on a light switch across the home?
I imagine that, if the devices and protocol all play well, INSTEON could work well in homes with just a few devices. But with "millions" of devices supported per network per the advertisements, I'm curious to see how larger networks play out from a reliability standpoint.
Chris
Chris
		 Can't tell you how angry I got when I had a Z-wave module burn out and then the network routing started slowing down, etc. and the only option I had to fix this was to delete everything (factory reset the remote) and re-add all my working modules.
   Can't tell you how angry I got when I had a Z-wave module burn out and then the network routing started slowing down, etc. and the only option I had to fix this was to delete everything (factory reset the remote) and re-add all my working modules.   This and the fact that moving modules requires removal/re-add to remote became a negative in my book for using Z-wave.
