Sources for Small motors??
The only relay i have right now at my house is a HAI 10A07 which I use to control the garage door and pizo sounders. Can this be used or is the DPDT relay the one that should really use?
Never mind I answered my on question about using the HAI relay.
I would be hesisitant in using this for your relay as you would need two of them and turn them on/off at exactly the same time.
The attached Drawing will just give you an idea of how you need to set this up. Still be very careful, as you may damage something if you wire it wrong, work at your own risk.
Mustangcoupe
What are you say could get damaged the Relay, Omni Panel, or the Motor??
Mustangcoupe
If you miswire something ... ALL.....
But more then likely my concerns would be your OMNI, and the power source you are using to drive the motor. (relays and fuses are usually cheap)
And this http://RSK.imageg.net/graphics/uc/rsk/Supp...50249_DS_EN.pdf for controller relay two. ( i don't really know what I'm suppose to attach to the coil and to the NO/ C)?
Sorry phenix, I missed your reply.
The Coil would be wired to whatever is controlling your relay. maybe your omni (if it is rated to drive relay) looking at the RS package, cross the NC to NO 's in an X connect the commons to the motor, and connect the no's to your power supply.
Hope you can follow that explanation.
The Coil would be wired to whatever is controlling your relay. maybe your omni (if it is rated to drive relay) looking at the RS package, cross the NC to NO 's connect the commons to the motor, and connect the no's to your power supply.
No problem Mustangcoupe
I did a bunch of research online and stumbled my way through it. I tested it out with a 9v battery and it worked great. Thanks for the help
