Hey From Ireland.
Been reading this thread with a lot of interest, and i have come to the conclusion that this is something worth the investment. but im not 100% sure if i have all the details correct.
I have 110v regulated power from a step down system, filtered and used for some amplification systems. this will power the meter.
What I am not sure about is monitoing my primary feed. The power here is 240v [238v and the current meter reading] and running at 50hz.
Can i use the meter to monitor this for a Single feed by clamping the primary Live heading to the 60amp breaker? Sinlgle Phase supply
I also read that there are support for 2 probes, but i think that implies 2 for 110 or 1 for 220, but that may be due to the way power is suppiled for 220 in the US. Akain to a 3 phase supply. So, the question is - Can i monitor 2 feeds on the one device in a 240v single phase configuration.
thanks
Finally - what link do I use to take advantage of the offer if these questions pan out? I will be in the US in 2 weeks so can easliy have the device shipped to my location in the US.
cheers
Damian,
We have recently implemented a firmware version for the ECM-1220.H to allow it to monitor Euro-systems of 220V/50Hz. Fortunately in your case, since the ECM-1220.H Pkg comes with two current transformers (CTs) you can monitor your entire panel and also a seperate load with the second enegy monitor channel/CT. If you are interested, please email [email protected]
Paul
