I am still working on the review. It is my higher priority right now (I had to deal with some other personal issues in the last 2 weeks, so I haven't had much time).
Thanks for the update - looking forward to your review.
Brian
It looks like things have been a little quiet here.
Any sucess stories, likes, dislikes?
Brian
Homeseer support.
In case anyone is wondering, Blade is nearly done with a plugin that works great with this unit. I've been testing it for a week now, and there are few things to wrap up before it's ready for everyone else to use.
I've been told several times they can support my 600 amp service, but my emails are typically not replied to. My last email about two weeks ago I asked how to get a system put together for purchase, never got a response.
Brian
Btechrep:
Are yor own CT's available in a UL labelled version yet?
If not can you please recommend a specific model from Magnelabs that is and will work for a new construction 200A service? Would the SCT-0750-200 work? Does that come with a plug for the Brultech unit?
THe main panel is installed in my house, put the power is not on yet. I hope to get the electrician to put the CT's in before the power get's turned on. From what i understand he can install them and run the cables to the outside of the panel and i'll plug them into the unit later right? I want to have UL listed CT's so that there's no argument with the electrician.
On a side note. My Electrician is proposing a whole house surge supressor that sits on a set of breakers from the panel. I was expecting the surge protector to be 'inline' and 'upstream' of the main breaker. Is the way the electrican is proposing a normal way to do this?
We are expecting our UL "E" number any day now, however, it may be another month before we get the UL labeled versions.
Magnelab CTs are compatible with our units and yes the SCT-0750-200 is the proper model for the SPLIT-200 substitute. If this is a new installation (panel), you may be better off with magnelab's UCT-1000-200 donut type CT since it is lower cost and higher accuracy. The disadvatage is that the line wire needs to be threaded through the middle of the CT which may be done when the panel is installed.
As for the surge suppressor, I don't know much about them so maybe someone else may know.
Paul
