shadowhunter
Greetings all,
Although I currently am not running any hobby-board components as of yet,(on the horizon I think) I am hoping to gain some assitance or knowledge as to an issue I am having with my 1-wire setup.
I have been noticing sporadic spikes in my humidity readings (this ofcourse affects dew point too) There does not seem to be a rhyme or reason as to when it happens. When the humidity is low ( around 50%) I will occasionally get a spike to 100% and then it drops back to the current reading, and on occasion it will drop out to 0% and then back up to normal.
Background on the station:Last year I had an electrical spike, due to a storm which took out the serial adaptor and apparently the temperature sensor in the WS itself too. The wind direction and speed are still functional. I have replaced the DS-9097U(I think)
with the Link-12 and have added a TAI-8540A Temp/Hum sensor and this is where I am seeing the spikes. I am not sure if the WS is causing an issue, or if there is an issue with the Temp/Hum sensor.
This past weekeknd I re-ran all of the wire from the roof to the PC, so now everything is in true linear form and all of the same wire. Yet the spikes continue.
I am hoping that someone may be able to shed some light on things be fore I start replacing part by part, which I may do anyway
PC Specs:
PII 450
450 MB RAM
Monitoring with Weather Display
Thanks in advace, my appolgies if this is the wrong place to post.
Jim
PC Specs:
PII 450
450 MB RAM
Jim
