beelzerob
Ok, I am very slowly beginning to understand this.
I understand now that the common off a 3-way switch isn't a matter of choice...it's a mechanical fact. So it's definitely the one marked "common", and with the off-color screw.
So, the point of the 3-way switch is to connect one of the two other wires to the common. If I take one of those two wires...and wirenut it to the common wire...then it's like I've "frozen" that switch in one position, right? Because then...the other switch WILL turn the light on and off by itself.
So if I REALLY wanted to get fancy, and to make sure that switch A turns the light on when it's up, and off when it's down...then while the power is on, I should manipulate the switches so that switch A turns the light on when up, and off when down. Then, turn off the power, remove switch B, and wirenut together the two wires that had been connected as a result of the switch position. (which, once I remove the switch, I can use my continuity tester to see which wire was connected to the common).
Then, going back to switch A, I'll now know which wire gets connected to the common when the switch is up, which means the OTHER wire is no longer being used. I can then turn the switch off, and with the power on, the wire that has no voltage is the switched hot, and the other is the hot hot.
Have I finally figured it out???
<_<
<_<
