Depending on how much power the strobe uses, you may need to use a power brick and a relay connected to an output to provide power to the strobe light.
The code should be easy, should be something along the lines of:
Code:
ON ANY ALARM TRIPPED
SET My Strobe Output ON
ON ANY ALARM CLEARED
SET MY Strobe Output OFF
Will give this a spin. If it doesn't work off the main board, I'll try draw the power from the optional power supply I've got installed in the can that I use to wire the smart card readers and many of the motion/smoke/CO detectors.
