I think structured wiring cans are popular because most people are not going to have a need for an equipment rack. So the can allows them a nice way to have all the structured equipment in a single place with a door for a nice clean look.
The fact is that it is actually cheaper NOT to use all the prebuilt structured wiring modules. I've done both actually. I used structured wiring stuff in my house and I used more rack mounted stuff at my parents house. I did mine first and I also have limited rack space due to the rack being under a set of stairs. I am working on my parents set up now (so I've learned some stuff) and they have more space and a full size rack. To be honest, I'm actually using rack equipment for Coax and telephone distribution, but I'm going to end up mounting it on the wall rather than using up rack space.
I already discribe how I made my own RG-6 distribution panel out of a blank 2u rack cover and barrel connectors. I think the blank cost about $10 and the barrel connectors also cost about $10 (going from memory here). So I have 45 spaces for about $20. Structured coax panels (like you have in the above picture) run 2-3 times as much money.
To distribute telephone lines, I used a structured module in my set up. In my parents set up, I bought a used 1u 24 port network patch panel and simply daisy chained the telephone feed to all the rear connections. In both setups, I terminated all my cat5e wires into a cat5e patch panel. To use a run for telephone, I simply take a short patch cord and plug it from the correct patch panel to the telephone distribution panel.
For network connections, you show a 16 port network switch in the picture above. In both installations I did, I've used a 24 port gigabit network switch that is rack mounted. So again, it makes sense for me to have the network switch, telephone patch panel, and the cat5e patch panels that I have terminated all the runs from the house all in the rack. Otherwise I am going to be running a bunch of patch cords from the rack to the structured wiring can. By having everything in the rack, I can use very short patch cables.
