Skibum
Thats what PC touchscreens with a nice GUI interface are for... displaying the data
I guess actually SAVING power is not you thing then?
Got some tech support from TED company and tried to located the powerline transmission and path problems.
I have a 220 dryer coupler from Smarthome and I put ACT filters on 2 PC's (I do have a working X10 setup that I am actually pleased with) but can not get RDU units "the receivers" to see the 1 second pulse except at outlets that are not were I want to see or near the PC with Footprints software.
Fustrating. Tomorrow I will shut down all breakers and see if the transmission can be seen by the receivers.
TBC
TBC
over at homeseers forums.. a guy posted how he got ted to work with x10... that is the only reason why I have not gone with ted... due to me being mainly x10....
BrettS did it.. read it here... {sorry for passing you to a diff site}
http://forums.homeseer.com/showpost.php?p=...p;postcount=142
or just the entire thing...
http://forums.homeseer.com/showthread.php?t=123763
TBC
Thanks for the filter ideas, yes I am using a few but the refrigerator needs a 15 amp so that is in the works. I am try to see if X10 and TED can work together? I know and have lived with X10 and its design. Until I can replace everything with UPB which will take some time.... I want to have a power monitor that can work with X10 .... trying and searching for a possible solution.
I posted a new topic on X10 hoping to get a better understanding of the powerline activity I am seeing. I wonder if my cm11a is also dying... it has been creating some problems (chicken or egg) with the existance of TED and maybe it is a cause or a result of TED, cm11a, smarthome signallic all working against each other. I do not know yet?
continued ..... Thanks again , all
 Yes, I agree I have X10 pretty stable but recently my new TED and legacy X10 are not working together.
An isobar 6 , I am going to check mine. What did it do on the powerline?
I saw an Intermatic Surge Protector (whole house) would this be the best configuration and get rid of local surge protection?
I have 3+ filters and the X10 cm11a, signalinc, phase coupler at panel, TED are all the environment.
Just found that the flood of BSC BBK is the TED MTU transmitter. Now I am worried, when I turned it off powerline went clean according to the testerlinc and my logs. I had crazy X10 lighting this AM and it looks that MTU was flooding the powerline and the signalinc was spraying everywhere..... Events using X10, that have run for years now have changed.
Need to run some HS events with MTU on & off. Then check for results.
I am getting to a cross-road. contunued later.
I think you will find that TED and X-10 are not compatible with each other, as expressed in hundreds of posts, here and elsewhere. There are three solutions currently know. 1) Don't use TED, 2) Don't use X-10, or 3) set up an X-10 isolated powerfeed to run TED on so TED and X-10 don't interfere.
I have not seen posts that are that clear and in fact TED support has been real helpful in trying to get this envoronment to work.
Your suggestion # 3) "3) set up an X-10 isolated powerfeed to run TED on so TED and X-10 don't interfere.
" .... from what I have observed in that last 2 days also needs to X10 block that line to prevent TED MTU signals from reaching the rest of the X10 environment. It appears that they foul up or confuse the X10 transmissions.
I just tested the time it takes to X10 dim a light;
X10 dim a light to 10%, with MTU on 12 seconds
X10 dim a light to 10%, with MTU off 5 seconds
It appears that the MTU blocks the cm11a transmissions.
Can that be the explaination?
Further I have tried some of my HS events that have run for years and I am seeing some crazy X10 powerline activities in the process. I am going to try to clarify the problems here. continued.
I had to send this hardware back as well as my X10 went nuts when this device was online.
