DRB
After receiving a free firecracker X-10 kit I am ready to start building a complete home automation system. Being a newbe I need the help of you experts in the correct hardware choices for building a reliable system.
Since this is just a hobby and am not rich, I am trying to keep the cost down as much as possible but want it to work correctly.
The system will be installed in a single family ranch style house under 2000 SF. I plan to eventualy control most if not all of the lights, including the basement. There will also be various lamp and appliance modules throughout the house. I also plan on controlling heat and air, and much later will play with the video aspects of X-10. Most, if not all, of my devices will be 2-way.
The switches will be the SwitchLinc Plus or Lightolier Compose 2-ways. I have one each on order to see which I prefer.
One thing I think I read was that some homes require a coupler/repeator? installed by a electrian to the main box. What and were do you purchase these repeators? Is this something that affects only an unlucky few, or do most large systems require this? Also would the SmartHome BoosterLinc Plug-in PLC Signal Booster solve this problem with out the need of a coupler-repeator? Is the best plan to start the system without any of these extra componets and then add only if your having problems? If that is the case, would you first add the BoosterLinc, and then if that didn't work then have the coupler installed?
My last concerns deal with the transceiver and the computer interface. Currently I am using what came with the firecracker kit, the TM751 and the CM17A. On a bigger system do I keep using the TM751? Do I install more TM751 in other locations of the house? Do I or can I have these set to the same house code? I realize after I get more than 16 devices I would need more set to a different code? What about whole house transceivers? Is this something to purchase only if I am having problems? Would a set-up require more than one if there is more than 16 devices? The CM17A I plan on replacing with a PowerLinc USB with mermory controller and they become avaiable. I can't think of any questions on this.
With me being a newbe this info may be confused or incorrect, so any and all help or comments would be appricated.
DRB
DRB
