hucker
Well we've been in the house over a year and most of the kinks have been worked out.  The wife mentioned the other day that the house seemed cold especially at night.  I took a look at the temperature logging and saw that if anything the stat temperature was slightly higher than expected and the room temps were slightly lower than expected.
Sort of figured that can't be...
Turns out that at night there is a set back that drops the set point a bit and causes the furnace to not run for several hours... AND guess what is right behind the stat? The media closet's power supplies routers, firewalls and PC... totally skewing the stat temp when there is no airflow in the house.
The best of plans....
