I read some of the ugly stuff on the TT0000 (of whatever model it is) and it got me to thinking about two questions I hadn't really considered before:
- Is there some place that does a feature comparison of all the RF/IR (Z-wave, X10, etc) thermostats?
- Are they generally dependent upon the/a PC and its software for cycling on/off?
For instance, my current one I program manually, though a PITA method of setting start/stop times and temperatures for every day throughout the week. Annoyingly enough, I have to switch it between hot/cold (I've seen expensive ones that'll do this for you, though I've never understood why it has to be such an expensive feature if you keep the warm/cold temps reasonably separated (by at least a few degrees) it shouldn't make the system cycle from hot/cold too often fo worry about.
Anyways, though I dislike the manual programming, I also am not that crazy about having to rely on my PC being up and operational in order for my HVAC system to be operating properly. I can see where the PC would make it a lot easier to DO the programming, but once it's done, I'd like the unit to be fairly independent. Possibly doing some interesteing stuff like tracking on/off data and temperatures and sending the data to the PC for me to analyze and see if there's something I could do better to improve quality of life and/or economics of the system.
Given all that, anyone got any inputs/suggestions/comments? I was read to go with the TT000(whatever) since it's basically the only one I've found (at a WIDE price range, BTW, I found one place that had it for 169, vs. 240 or so at another place). Are there other options? How do they stack up against my requirements/desires above? Thanks for any insights,
Terry
Terry
		 , I believe as it could run on the same 12v supply as the LM34 . . .
