So I'm digging more into the programming of things, but cannot figure how how to do this.
What I want to do is set a zone to "Not Secure" therefore triggering the alarm to call out. I've got two scenarios that I would like to do this with; 1) revolving around temperature alerts, 2) revolving around timed events.
Ideally I would like to program these events to set a zone to "Not Secure"; eventually triggering a dialout. I've also thought about the idea of connecting one of the zones directly to an output with an EOL resistor; but not sure of the voltage or hazard this may cause.
So I guess my questions are the following:
1) Can you toggle a zone between Secure/Not Secure via programming?
2) Can you connect a zone directly to an output with an EOL resistor?
3) Can you cause the system to dial out via program; other than directly triggering a zone?
