ctay
I am having trouble connecting to my Litejet for the first time through the elk. Lighting changes in the Elk have no effect on the Litejet. I am connecting through a ELK-M1XSP that has been enrolled and is running the latest firmware. The litejet is on firmware 7.0. The serial cable is good and I am able to connect to the Litejet through this serial cable when it is connected to the laptop. The M1XSP is enrolled and communicating with the M1G (steady blinks every 1/2 sec). I have the mode jumpers of the M1XSP set to 1 1 1 0. I am connected to the serial port 1 on the Litejet with dip switches 8 and 6 on. This is a litejet 48 so i can not connect to the port 2 as that connects the two panels together. I set the format for the lights in ELK RP with the format stated in the manual (Serial expander, dimmer). The M1XSP is addressed #2.
I am at a loss. I have tried everything I can think of and have looked for every document that says anything about the setup of these two that I can find.
Any ideas?
Chris
Any ideas?
Chris
