I have been using Elk w/ Nextalarm for a few years without problem. My last reported events was this past summer. No events since then to report until 2 recent alarms (false burglar and false smoke). Both of those resulted in no reported events to Nextalarm. No changes have been made to either system except I did install Elk RP back on my PC and I may have loaded an old database which may have made some changes but everything else with the Elk works fine.
I troubleshooted the ABN of Nextalarm and found I did not receive a notification after 5 minutes of being off line like I used to. I called their support and went through all the diagnostics and he stated he could see my ABN and when I connect a phone to it it worked fine, just the Elk was not sending a signal to it. OK...So I changed the wires from Elk to ABN, 3 different ones to be exact. Nothing.
Since it's been a while since I installed the ABN I cannot recall if I had to do anything special to ELKRP to tell it to use NextAlarm and the ABN. Under the Phone section I have NextAlarm with CID reporting and an account number. All my reporting codes are correct. I don't think there is anything else to change or check.
I don't know how to trouble shoot the problem. I truly think its the ABN but support says no. The guy doesn't know why it will not report off line status after 5 minutes and a ticket was submitted which I haven't seen yet. I have Vonage and tried to hook the Elk to the 2nd Phone line in the Vonage modem but I got nothing with that...No dial out or dial tone or any tones.
I plan on leaving NextAlarm but I want to fix this issue if it's the Elk.
