SteveInNorCal
Hello. I’ve got almost my entire house running on PCS PulseWorx switches with an Elk M1 Gold acting as the master lighting control.
About a week ago, my front porch light (controlled by a PulseWorx WS1D or might be a WS1DL) started going off randomly once or twice during the evening hours. We have to turn the light back on manually. It doesn't seem to happen every night, either.
Until this problem popped up, everything operated 100% reliably for the 1-1/2 years since I installed the system.
The front porch light switch sends a link to an adjacent PulseWorx KPLD-6 Keypad Load Controller Dimmer which controls outdoor lights on the garage. I think both the front porch light controlled directly by the WS1D and the garage lights controlled by the KPLD-6 load control are going off (I need to confirm this the next time the lights go off).
There are no new loads or appliances installed in the house that might be causing noise. Electrically, nothing has changed since the original installation.
Any recommendations on trouble-shooting and diagnosing the cause? Should I hard-reset the switch and reprogram it? None of the other switches in the house are affected by this problem. How can I isolate the problem between the Elk M1 and the light switch / load controller? It's been a while since I set everything up -- I seem to recall being able to examine a log of commands send over the system. Would this help pinpoint the source of the problem? How do I get to the log?
Any help would be much appreciated!
Regards,
Regards,
