Right now I have a 10A11-1 (Rev C IIRC) two way voice board and 33A00-4 Alarm Console w/ Speaker and Mic. spoken messages from my OPII are output there.
I also have an 8 zone NuVo GC whole house audio setup, and i was planning on using NuVo's source 6 as a paging channel.
I currently have a mini-Stereo to Stereo RCA cable connecting the two-way voice board into the source 6 inputs on the GC. I was planning on running some bell wire (20ga) between the page output on the board and the mute/page trigger on the GC.
The back of the HAI is looking for a 3.5mm mono plug afaict, so i was planning to take a cable with 3.5mm mono plugs on both ends and cut it in half, then tie each wire to one wire of the bell wire.
Will the voltage of the page output be sufficient to trigger the page functionality on the NuVo? Or do i need to do something like Worthington's recommendation for Russound/HAI page integration?
Anything else i should be aware of (other than powering down the OPII before i hook it up)?
