I recently noticed an issue with my SA USR1130 dimmers (actually HAL branded, IIRC). I have the top rocker set to set the dim to a fixed value, i.e. 30%. If I press the top rocker, the light comes on at 30% and if I dim it a bit and hit the top rocker it will brighten back to the 30%. Now if I brighten it past the 30% and hit it again, it does nothing. Similarly, if I turn it off and then back on, it will go back to the brighter value.
It's as though I have it configured for the top rocker to be "Go to last on level". Further investigation determined that if I turn off the "Save last value" option then it behaves correctly. I think this is a bug, since this eliminates the ability of having other links that may want to use the "Last level" option.
Anybody else seen this problem?
gk
gk
