I have a TechLighting-branded monorail track system in my office that I'd like to control. The instructions for the transformer (
http://www.techlighting.com/Products/Fixtures/MonoRail/MonoRail-Mini-Surface-Transformer-300w-EL-LED) state that "This product may only be dimmed with a low voltage electronic dimmer." and that use of a standard dimmer will void the warranty.
Does anyone know where I could source a UPB-controllable "Low voltage electronic dimmer?" Nothing that fits this description seems to come from HAI. The world won't end if I can't dim the lights and can only do on/off, so if that's the case, should I use a UPB relay switch or is it possible to configure a standard UPB switch in a "non-dimmable" mode without any ramp in order to preserve the transformer? If I use a non-HAI switch does that cause any problems with my Omnipro-based UPB setup (currently I'm 100% HAI switches).
Thanks!
Thanks!
