Deane Johnson
I'm experimenting with a Pulseworx dimmer to see how I like UPB. Just discovered that the way my wall switch is wired is that the electrician has simply run a two wire plus ground piece of romax down from the fixture to the box. This means there is a hot wire, a load wire, and a ground available.
Has anyone been successful just using the ground for a neutral with UPB. Any problems. Good idea, bad idea?
Does this mean I should forget UPB as a possibility for me? If so, what does work in these situations?
Appreciate your thoughts.
Deane
Deane
