WithoutATrace
Good Evening,
I just started putting in a large installation and ran into an issue. Many of the lights in this house have two or more switches. You know, two switches on opposite sides of the room control one light. The problem is, the gang box on one has three wires plus a ground. Two red and one black. Wiring the known hot to the UPB switch, and the "common" from the original switch to the neutral, the last one must be the load!
The switch seems to work ok, but when you click it on, the light doesn't turn on! If you flip the switch on the other side, it seems to turn the load wire into a hot wire. Is there something simple I'm missing here or do I need to install a UPB switch on both?
