I am still confused on this. At first, i assumed it used a neutral wire to send pulses to it.
So lets say a single pole light switch that would normally have the wiring routed like this:
White: Neutral Bus Bar -> Switched (spliced together) -> Light fixture
Black: Breaker -> Switch LINE -> Switch Load -> Fixture.
Would be changed to something like this:
White: Neutral Bus bar -> UPB Controller -> Switch -> Fixture
Black: Breaker ->UPB COntroller -> Switch ->Fixture.
Meaning that the white is now being used in the switch level. Each switch is looking for a specific signal or pulse to be sent across the neutral line. In the cases where a switch isnt a upb controller, the white would simply be spliced as usual?
Now where the confusion that I have is when I look at UPB switches. There is a Hot, Neutral, then Transmitter wire. For instance, it almost seems like theres supposed to be some 18 guage wire fed to each switch to act as a signal. Which means I need to retrofit my 4 year old house?
Does anyone have a good article for me to read, or video, etc?
