no i haven't done anything yet just bought the house 2 weeks ago and i still have about 5 or 6 more switchs to install..... to be honest it doesn't bother me right now..... and if it was up to me i would throw the microwave away to solve the problem... but the soon to be wife will not like that idea.AutomatedOutlet said:Wireguy, Have you tried putting a filter on the microwave? The ACT 15 amp filters will normally fix this issue if it happens.
Tell her that you expect more home cookingif it was up to me i would throw the microwave away to solve the problem... but the soon to be wife will not like that idea.
so what you're saying here is the X-10 filter actually generated additional noise? does this seem counter-intuitive to anyone else?
These filters are LRC circuits that are electrically coupled to the device plugged into them. I imagine the resulting combination could interact in unexpected ways sometimes.DeLicious said:so what you're saying here is the X-10 filter actually generated additional noise? does this seem counter-intuitive to anyone else?
You may have larger problems. If that "quality" of work was consistent, then all your switches and outlets would probably be suspect.Event5 said:Then.... we started going to each panel and tightening the screws on every breaker and the neutral bar. We also tightened the large feeder lines to each panel. We found nearly all connections loose some as much as a full turn.
